Robert16star
- May 13, 2007
- 14
I drained my lower unit and because I had some ice in a bucket of water nearby I thought it might help the draining process by warming the lower unit with my propane torch. Well I'm not sure but I don't think it helped. After refilling with new grease I next started the engine (it took a bit as it hadn't run in three months). Once I had it running it wasn't long before I had grease oozing out of the vent holes above the prop and from out behind the propeller it's self. Not good right?
I re-drained the grease for fear there would have been water in there and didn't want to leave it that way with temps dropping. It doesn't seem to be leaking when not running but I'm almost certain it will once I run it again.
I've attached some lovely photos that I hope you can take a look at.
Did I melt a gasket or seal? Is that where the oozing grease is coming from? Can I it make it right by spring time.
