montanafos
Thread starter- Joined
- Jul 10, 2010
- 28
First time I've seen this with my outboard (1996 Merc 150 EFI). Back home from a few days (10 hours of run time max) and after a day of sitting in the driveway I noticed gear oil leaking from the small vent / hole just forward of the upper drain screw. Was enough of a leak to puddle on transom saver and then on the ground a bit. Drained the lower unit (this lube has 20 hours on it max over 6 days total). A bit of water came out of the lower drain first (about a tsp) and then the gear lube in the quart jar. Would love any thoughts as to what I might be getting in to. Would love to hear that the drain / fill screws just need new gaskets...but the lube coming from the hole leads me to believe it's more than that. I've attached a few pics. We only have a couple local shops I'd take my outboard to and they're booked out a ways. Is this potentially a fill it again and run for a few days and I'll be ok? There's maybe one more trip this fall and I'll get it worked on and or winterized until someone can work on it.
Appreciate any insight...
