Lower unit Johnson
Brian Carrico
I would like to know if a 1973 65hp Johnson/Evinrude will work correctly on a 1978 70hp Johnson/Evinrude. I installed the lower unit today but have no reverse. Have forward gear but hard to shift into. Have neutral but not correct place on shifter. I had to set the shifter rod at the 1973 65hp spec 21" and 11/32. When I tried to set the rod at the 1978 70 hp spec 21" and 23/32" in neutral the rod runs out of thread.
I used the 65hp lower unit onto the 70hp engine
70hp - Model # 70873C - Serial # J0005275
65hp - Model # 65ESL 73R - Serial # J3886365
Please Help, Thnaks
Honorary Supreme Mariner
The 73 lower unit shifts to forward with a DOWN motion of the shift rod.----The 78 shifts to forward with an UP motion of the shift rod.--------------You will need the 73 linkages on the 78 motor to make this work !!-------Also the 73 lower unit has an oil pump to aid in shifting .------So with the driveshaft turning it will shift easier.
Brian Carrico
Sounds great I will look into this tomorrow. I'm a hoarder LOL so I still have the 65hp top end that is locked up. With good linkage, Thanks!!
Brian Carrico
Thanks for the help Racerone - I changed over the linkage but still had issue. Removed lower unit reset the shift rod to 21" and 23/32" the 1978 70hp spec. Installed unit and works good. Before being a member to this site I was ready to purchase another lower unit. Thanks again to Racerone and this web site for the help.
