lower unit interchangeable years for 20hp?
Fowlaction
Hi I've been a long time lurker but never have posted before. I have a 1992 Evinrude "tracker" 20hp, My question though is what years of lower units can be bolted directly on if I find a used one. From what I've found online it looks like could use an 1980-2005 as long as it was a crossflow version from a 20-35hp unit. Does this seem right? cause my mechanic has been telling me I have a one year only motor and that its basically garbage. I'm just a little worried that he's trying to make a buck off me by selling a new motor to me and flipping mine
Chinewalker
1990 on up 20, 25 & 30 would be a perfect fit, part number 433428. 1980-1989 20 & 25 (with through hub), 30 and 35 had some subtle differences but I don't think there's anything that would prevent it from working. Nothing unique about your 20 - it's the same basic 31.8 cube motor that was built for a generation. The 28hp model units will NOT work, though, as it has the exhaust exiting the AV plate...
flyingscott
Maybe the decals on it were a 1 year only maybe want to get a second opinion.
Honorary Supreme Mariner
Your mechanic is not to be trusted.----You are correct in that many years will bolt on directly!!-----The 3 cylinder lower units are different.
Fowlaction
Would this one (http://www.ebay.com/itm/2002-Johnso...afbba975f:g:3N4AAOSwxcRW9Du2&vxp=mtr#viTabs_0 ) work? from what you posted it seems like it should just wanted to double check before buying it
