Lower Unit HELP Please!!!!
Glastron 176 1976
Have a evinrude 140783s which apparently is a 1977 140hp 4 cyl 2 stroke.
Last weekend we had it out all weekend pulling tube and crusin the lake. Everything worked great till the end of our weekend we wanted to take one more trip. I fired her up and went to engage it into forward but no go just a grinding noise from the engine. I pulled the cover off and attempted to shift manually by hand it moved more than normal but did ingage. I throttled her up and she took off for about 5 feet then popped out of gear and I could not engage by hand now I put it in reverse which still works like normal and got it back to shore. Cables all seem to b working properly. I did a lower unit oil change that Friday before we took it out. Is there anything to look at first or should I b looking for a new lower unit
sutor623
I know you just changed that LU oil, did you pay attention to see if there was any metal chunks in the oil? Any water? If I were you Id drain the LU again and see what you find. Put it in a glass mason jar and see if water separates from the oil.
When you put the motor in forward by hand was the shift linkage still attached? If not, then that may be why it popped out. Did you try adjusting the shift cable to the extreme in one direction to see if it will go into forward and then not reverse? When these cables wear (stretch) out they tend to only shift well into forward OR reverse.
