Lower Unit Help, Mercury outboard 85hp
NateAnderson
I replaced a lower unit on a friends 1980's mercury 85 hp. The replacement was used and seems to be stuck in forward. When it is off it only spins clockwise and clicks. When I installed it, same story. The shifter moves freely but the prop stays in forward. Not very experienced so could use some advice.
Chris1956
Yes, it sounds like it is in forward. Turn the shift shaft on the gearcase CCW until it stops. Now use a small cresent wrench to turn the shift shaft a bit more CCW. If the gearcase is working, it will "click" into neutral.
