dragula65000
- Apr 14, 2004
- 180
1989 175 v6 90 degree johnson outboard. Went to repalce the water pump this weekend, and could not get the lower unit to seperate. I disconnected everything, and it was hanging, but it's hung up somewhere inside the motor. Splines maybe? I didnt disconnect the prop because I don't have a big enough socket, and can't see a need to. I disconnected the linkage, and when its connected, in forward the unit is higher, and reverse it hangs lower. Is the reverse gear making it hang up?
