lower unit grease Wards Sea King (Clinton)
rtrav001
Am working on a Wards Sea King 5 HP from about 1979 and need to replace the original grease in the lower unit. This is not a liquid (not high vis 80/90 gear lube). What kind of grease should I use?
CFORBERG
Re: lower unit grease Wards Sea King (Clinton)
Lubriplate 105 (available at NAPA) works well for non-shift lower units. Full shift units should use a typical lower unit lube.
rtrav001
Originally posted by CFORBERG:<br /> Lubriplate 105 (available at NAPA) works well for non-shift lower units. Full shift units should use a typical lower unit lube.
Thanks - I'll give it a try...
