lower unit gears and bearings
joe johnson
so i have tore my lower end apart to check my gears out and have to replace them so now im wondering should i change all those little flat bearings out as well they seem in good shape i am just worried a bit about the metal debris from the gear teeth chipping and getting into them??????
Faztbullet
If you have had metal circulating in the oil I myself would replace all the bearings. If you are changing gears and bearings you will need to recheck shim height...
Faztbullet
Shim distance between top of pinion and bottom of bearing cap....It takes a special tool or carry it to a dealer and have checked.
Honorary Supreme Mariner
Changing gears and bearings is not the same level of work as installing new sparkplugs.
joe johnson
thanks faztbullet i will do that do you know by chance what the name of the special tool is
