Lower unit fill hole is blocked!
debsfishinboat
My 1975 90 hp merc. there is something in the way for me to pump 80-90 in to the lower unit. I can see it thur the little fill hole, it is something inside, blocking the hole. Moving my gear shift, don't help. WHAT CAN IT BE? And I suppose I fill it to the top hole with lube, right. Thanks. "Deb's fixer"
rickryder
Re: Lower unit fill hole is blocked!
Fill from the bottom hole till it runs out the top hole.
jerryjerry05
You try moving it with a screwdriver?
GENTLY push on it.See if it moves.
Was there a small magnet on the end of the drain plug?
Pics?
Chris1956
It is either a chunk of metal (bad) or a piece of an old gasket (not so bad). See if you can determine if it is hard (metal) or soft. If soft, try a small screw or punch and see if you can grab it and drag it out.
If it is a chunk of metal, the gears may be bad....
Silvertip
Are you sure you are looking at the DRAIN/FILL hole? You drain the lower unit by removing the big screw in the underside of the lower unit gear housing. You remove the top screw to serve as a vent. You then FILL the lower unit throught the drain hole until fluid comes out the top hole.
Faztbullet
Your looking at the top vent screw and what your see is the top of bearing race....
