lower unit drain plug
omaha
ok so i am having issues with getting my drain plug, and vent hole. any tips? motor is a 93 johnson 2 stroke.
dew2
Re: lower unit drain plug
You might want to reread the post?? What issues?
wilde1j
If trouble is removing, use one of these (impact driver):
Always works.
JRoach
I had to use an impact driver to remove the drain plug on my 1990 Johnson 40 HP outboard engine. It worked great.
kbait
Some people apparently bring their motors to the Incredible Hulk to tighten the drain plugs! W/new plug washers, just cinch 'em up.. no need for hulkamania.
oldybutagoody
This simple piece of advise has taken me 50 years to learn. Better late than never.
boobie
The spec is 84-86 in. lbs. for tightening.
AlTn
same guy must work at "Jiffy Lube"
