markcerrone
Thread starter- Joined
- Mar 6, 2009
- 3
I removed the lower screw from the force 85 motor. I thought this was where I would inject the lower unit oil. As I was removing the screw I saw a second screw labeled vent. I then realized the vent was on the top just like the oil intake. I purchased a manuel and now realize this is some type of hinge for the gearing mechanism. The motor seems to operate normal. Should I still have it opened up and checked or is it that if this hinge or fork had displaced the motor would go into gear. It goes forward and reverse no problem. Just a slight normal gearing sound when going from neutral to gear. Is there any cause for concern?
