lower unit 1985 25hp jonhson water in oil
sween
i have a 1985 25hp jonhson and am getting some water in the oil of the lowerunit.wondering what seals to replace and where they are because i already have lowerunit apart replacing inpleller and is there anything else i should take care of at this point.thanks
Lion hunter
Re: lower unit 1985 25hp jonhson water in oil
Try replacing the vent and fill plug seals and see if it cures it.
tashasdaddy
agree, that is what i would do first, and check the oil after several uses.
sween
thanks i will try that. i was just wondering since i have it all apart should i go any further beyond the oil plug seals.there does'nt seem like much water in with the oil.
sween
water pump assembly
water pump assembly
putting new gasket in lower part of water pump.just wondering if i install as is.or need a gasket silicone or other.thanks
