lower unit 125 hp force- HELP
cory0319
125 hp force 1986
does anyone know which screw drains the lower unit oil??
jerryjerry05
Re: lower unit 125 hp force- HELP
On the bottom on the front.An allen head set screw.The recesed screw DO NOT TOUCH!!!!!!!!!!. Jerry
Firemedic09
they should be labeled one should say vent the other should say fill. when you lift the motor up the fill is going to be at the bottom on the port side of the motor . good luck
