Lower/out drive shift cable froze
BDUB09
So my new used boat has bad bellows and needs its shift cable replaced at the moment I am trying to figure out how to get the out drive off while the boat is in neutral its a 1969 mark twain v16 120 Merc model 1. I was told you can damage the drive if its not in forward and the cable that controls it is froze solid any thoughts. :facepalm:
Bt Doctur
Re: Lower/out drive shift cable froze
cut the shift cable between the end of the shift bellow and the gimbal, turn straight with screwdriver, remove drive.
If thats the part thats frozen, remove lower unit , then remove upper unit.
BDUB09
Thank you I'm about to cut the cable but dont get the part about the screwdriver here are two pics the first one is in between the out drive and cable bellows and the second shows the back of the cable bellows.SAM_0143.jpgSAM_0142.jpg I'm thinking about cutting it in the middle of the second pic
BDUB09
That's the spot to cut the cable...
Look at Ziggy's photo of the shift shaft.
That is what you want to turn with the screwdriver so it is straight the prop should be able to lock CCW (while looking at the bow)... if so your drive is in forward and ready to remove.
