Lower motor mounts release water?
Frankcaps
Hi Guys,
Is it normal for the lower mounts to leak water like seem in my video? The mid section where the mounts are located at the bottom there look like the mid section was cracked at some point when i removed those covers. not sure if that's normal... boat has been used like this for 3 years with out issues...
150 mercury offshore v6 1998
Thanks in advance for any help!
F_R
This is the Evinrude/Johnson Forum. If that were a E/J, water escaping from there is normal. But not that much. Probably because you have too much water pressure on those muffs. Try posting the question on the Mercury Forum.
