Just finished pulling my lower end and tested it out with air pressure and found a major leak around the electric shift cover, no cover gasket (1969 Evinrude 55 HP w/electric shift). Also, no leak around the drive shaft seal until I rotated it and giggled it a bit and then identified a small leak. Figured I would replace the seal and get a gasket for the shift cover and think I will resolve my water in the oil problem (I hope). Question is, how in the world would I be getting water around the shift cover on the top of the lower unit and how long should the plastic tubes be that come up off the water pump. The ones that are currently on there may be 1 1/2 - 2 inches long. Also, should there be any type of gasket or sealant between the water pump housing and the lower unit assembly and is there a need to put any sealant between the lower unit and upper unit. New at this and trying to fix all these little problems before they become big ones.
