pita482
Thread starter- Joined
- Jun 28, 2010
- 92
Hello, can the lower crank seal be replaced on a 1990 90hp force without splitting the block? Found the spring for the seal laying down in lower unit when changing water impeller, doesn't seem to be leaking, seal looks in good shape, was wondering if I remove the power head can the seal be popped out of the bearing case or do I have to split the block, or if it's not leaking just run it without the spring?
Any help on this would be great!
Thanks in advance!
Thanks in advance!
