iwombat
Thread starter- Joined
- Jul 12, 2006
- 3,767
I just got done replacing the impeller. I fired it up on the muffs to test it all out and I'm getting just a dribble out of the tell-tale. I'm getting a small stream of water coming out from somewhere under the powerhead though. Everything all worked fine before the impeller change (go figure).
This is a long shaft, and my theory is that the block of rubber that seals the pump to the water tube is too loose to force pressure up the tube and it's coming out the sides and following the outside of the tube up until it finds a place to come out.
My manual (non model specific) doesn't specify anything about how to seal this part up, or if it should be sealed. When I pulled it apart it was pretty much a mess of crud and pretty solidly set in place. So, cleaned it all up and now it slides around pretty easily.
Anyway, I'm sure someone knows all about this little item, including how to tell if it's worn out and how it should be sealed in properly.
