low voltage
damboats
new boat here.. twin 305 merc. just put in 2 new batteries and still reading low voltage on the gps with both battery switches on it reads 9v with just one switch on it reads 10 ............any ideas?
Bifflefan
Re: low voltage
Check the voltage at the batts. with a volt gauge. If 12 then check it at the GPS end of the wire. If 12 check the ground, if good, replace the GPS, if less replace the wire.
