Low Voltage - and Batt Charger issue
RiverD
I am having an issue with low voltage on my 2001 Bayliner 2855 (7.4 MPI). I have dual batteries with a switch and an onboard charger. I also have a genset (3 KW Westerbeke) on the boat. The genset will not start (turn over) if the voltage is not adequate. Lately - my meter on the dash has been reading only 11 Volts when I turn on the battery switch and the key. However the main engine will turn over and start no problem. To start the generator, I have to run the enigine in neutral at higher rpm to allow the alternator to increase my charge - the meter will read 13 Volts and I can get the genset to turn over and start. One of my 2 batteries has just been replaced and the other still tested good. Last night I also hooked up a portable charger/tester directly to the terminals and it indicated 12.5 Volts while my dash meter was still showing around 11 volts. There are other indications of weak voltage such as my trim not wanting to engage unless the engine is being run at higher RPM. I am also now having issues with the on-board charger. It is tripping my shorepower GFCI when it is switched on. I watched the charger while the switch was thrown and it sparked when turned on and then immediately tripped the GFCI. The battery cables are also discolored near the battery terminals and appear to have gotten heated up (this was the case before I put the new battery in). I am starting to troubleshoot, but don't know if the Volt and battery chager issues are related or not? I think tonight I will try powering up the charger without having it connected to either battery to see if the charger has an internal short. Gotta start somewhere. Any help would be appreciated.
ayaresr
Re: Low Voltage - and Batt Charger issue
Another option to test the charger with a load would be to disconnect all wiring from the batteries, and only hookup the charger leads, isolating whether the problem is in the on board wiring, or with the charger itself. As for the low voltage issue, while you have the wiring off the batteries, check what your getting on each battery individually if you haven't already. You may find you have a weak or dying battery. Its not all that uncommon to get a battery new that is bad from the get go.
EDIT: I should clarify, using a voltmeter on the batteries isn't a true test of whether or not they're good or bad, you really need to have them load tested to be sure, but if you see an abnormally low reading on one or the other, and there hasn't been any draw on that battery, it could give you a clue what's going on.
RiverD
Looks like my "Good" old battery may be part of the issue. I disconnected it and only have the new battery connected. Charged the new battery overnight with a portable charger - now reading 12.8 V based on the charger readout and the dash meter is now indicating 12 V (likely not very accurate - but was only indicating 10 to 11 before with both batteries). I also tried powering up the on board charger with it disconnected from the batteries. It did not trip the breaker or GFCI this time, but it smells burnt. I hooked it back up to the batteries and it did not trip but is now not charging the batteries at all. I may try load testing the old battery ro I may just get a new one later today. I have not really examined the wires in detail yet as suggested elsewhere, but may try that too. I was told to cut back some of the insulation and look for corrosion - not just at the terminals. Any other suggestions would be appreciated. Thanks.
RiverD
Dropped in the second New battery and went for a ride. My dash volt meter is now indicating 12 V or better at rest and 13 or greater with the engine running. That battery was only 2 years old, but I think my charger issues may have shortened it's life. Will install the new charger soon and report back. Also, I could tell a difference in the performance of my power trim with the new batteries (go figure).
