Re: low tire pressure
I have a 2001 Oldsmobile Aurora, and GM clearly explains the procedure of resetting the tire pressure warning light in my owner's manual. It takes all of about 3 minutes to look it up in the index, and 4 seconds to perform the procedure.<br /><br />I have to assume your Chevy has a similar procedure that's clearly explained in the manual. Check there before you do anything else.<br /><br />Before you reset it, you want to put proper tire pressure in all 4 tires. And I'm quite certain that 44 psi is NOT the proper tire pressure for you car. Check your door jamb for the tire pressure sticker and set it to factory specs.
