airdvr1227
Thread starter- Joined
- Jul 15, 2009
- 1,666
At low speed she wanders back and forth without any steering input. Normal?
What actually happens with the hull, water, and drive that creates the wander on an I/O?
Wander happens because it is a planing hull. Displacement hulls like sailboats don't wander because the water flows smoothly around the boat hull. On a planing hull the water flows smoothly until it gets to the transom and then it encounters a big discontinuity. Displacement hulls don't have this discontinuity. Basically, when moving forward, the hull creates a big hole in the water just aft of the transom and the water rushes in from the sides to fill the big hole and it gets turbulent back there. In the turbulent water created the rudder isn't real effective. The outdrive or lower unit doesn't have enough rudder area to counteract it and the boat wanders.
While what you say may be true and have some effect on the ability to run straight, it doesn't explain why my inboard (a planing hull) does NOT wander in the least. It simply goes where I direct at any speed. And no, it does not have the fins on the bottom that a comp. ski boat does. It's just a straight inboard.
