Low speed backfire 1977 9.9
jcoop86
Hello, wanting to see if anyone has experienced this before I really dig into anything. My 1977 Johnson 9.9 I just bought has a backfire at slow engine speeds. I got it running really easily. The guy I bought it from said it has sat inside for about 5 years. Once I got it fueled up with fresh gas it didn't take long to get it to start and run. I figured since it had been sitting I would let it run in water for a while to clear out any old gas that was left. Runs good, starts pretty easily. Just doesn't like low rpm and at the lowest rpm I can leave it and it stay running it will do a small backfire every 10-15 seconds or so. My guess is a dirty or varnished slow speed jet. I have a carb rebuild kit on its way. Has this happened to anyone else? My guess is the kit and carb cleaning and new plugs will take of it but if anyone has any other thoughts I would be happy to hear them
flyingscott
Yes it's called a lean sneeze turn the low speed adjustment to rich about a 1/4 turn should go away. Even if it does you should still rebuild the carb especially after sitting for 5 yrs. And if it doesn't rebuild the carb make sure everything is clean.
jcoop86
Yea I definately gonna rebuild the carb when the kit shows up, I was adjusting the low speed adjustment and I feel like it didn't help a whole lot, maybe a little bit better, that's why I assume there's varnish in the slow jet or something. I'm not expecting to need the parts in the kit because the carb looks brand new, like it was replaced just before they stored the motor away
flyingscott
Did you look at the float if it's cork that will need to be replaced as well.
jcoop86
No haven't pulled the carb yet, waiting till the kit shows up. But like I said I'm assuming the carb just needs cleaned because it looks like it's right out of the package
jcoop86
I will replace everything in the carb when I the rebuild kit arrives, pulled the plugs today and they are wet and oil fouled. Could that cause the sneeze as well?
Honorary Supreme Mariner
Does the motor warm up ?--------------Is there a working thermostat installed ?
jcoop86
Not sure on thermostat condition, the water coming out never seemed to warm up. Stayed cool after running 10-20 minutes
jcoop86
Rebuilt the carb, put in a new thermostat ( old one was stuck open, and tuned the lean/rich needle and she starts second pull and run as smooth as can be. Now it will idle as low as the linkage will let it
