Boating_Al
Thread starter- Joined
- Jul 30, 2004
- 66
I bought my 2000 25 AqualSport with a 2000 Mercury 225 EFI about 10 months ago and due busy schedule no-time to put it in the water. I would start the motor every month on the hose and it ran fine?till I let the gas go low in tank, after this the motor did not run, it would start & die. I took out all the injector & sent them out to be clean and completely clean the vapor tank(float was stuck) & replaced all filters(they were bad). Compression at 120-122, all cylinders. So now that I have the motor all put back together?I?m little bit concerned, maybe motor running too good.
The motor starts on first click, little smoke on start-up, but hardly any smoke while idle. If all is working as it should, should I see any smoke? Would you guys recommend going to premix & removing the oil pump. Motor has about 700 hours.
Thanks
Al
Thanks
Al
