fountain31
- Jan 13, 2009
- 5
I have been running fine all summer and this past weekend noticed the port engine surging then not being able to go above 3000 RPM. I have a pair of Merc 225 3.0L Carb 1997 that have run beautifully for years. I broke the carbs down and cleaned, checked compression all 115 cold start, yet when I run her at idle I get quite a bit of coughing and what seems to be back pressure on the fuel lines. One of the carb lines split open and another started leaking at the fitting. Replaced the 1/4" fuel lines and filters; does this indicate anything obvious?
Thanks
Ray
Thanks
Ray
