BreakOutAnotherThousand
Thread starter- Joined
- Aug 7, 2011
- 55
Volvo Penta 5.7 GSi PEFS
Testing out the system as I'm trying to diagnose a lack of power/misfire/exhaust backfire above 2500 RPMs.
It's not the S.L.O.W. circuit, knock sensor, and oil sensor are disconnected.
CTS resistance checks out on bench test. 10K on ice, 2K body temp etc.
Both injectors spraying fine, cleaned by WitchHunter when pump replaced. SLOW would otherwise kill one injector.
Pressure regulator has no leaks.
MAP sensor, TP Sensor, and MAT sensor all test fine. (yes this engine has one!!) Even though its an MEFI3.
Compression is 190 to 180
Cap, rotor, wire, coil replaced, swapped ignition module.
Timing set.
No codes using Rinda CodeMate.
No water in fuel, fuel cell has 10 hours on it.
Ran with hose in a 5 gallon gas can to eliminate bad pick up.
The only thing I found not to specs is:
HP pump has 39lbs
LP pump has 20lbs!!
Could the LP pump cause the above issue, or is my ECU fried? According to Volvo bulletin, if the ECU is history,
I have to buy an MEFI4 unit for $2,500.00!!!!!!
Timing set.
HP pump has 39lbs
LP pump has 20lbs!!
