Hi everyone. I'm trying to diagnose motor problems on my (new to me) outboard. Motor model is J90TSLECM. I bought the boat/motor about 1 month ago after it sat for about 2 years. Had it in the water only 2 times for trouble shooting. The issue is low power on acceleration. But, the funny thing is that the first hole shot each time I had it out was great. Drop the boat in the water, idles great at launch, pull away from the launch and it takes off great. Run down the lake a 1/4 mile or so, stop and turn around to go back and low power. Trying a few more times and nothing. I can eventually get up to speed but it takes a good 10-20 seconds. Then I have taken it back to the launch to hopefully minimize possible damage.
Things I have done. Compression test 105, 106, 102, 95, spark looks good with spark plugs in an grounded (haven't tried spark tester), decarb using both seafoam method and OMC Engine Tuner method. Replaced plugs. Checked plugs after run and it looks like 3 of 4 are firing good and one is wet with fuel(not the lower compression cylinder). Haven't done a lot to confirm that yet. I realize compression is low, but if that were the issue wouldn't it be a problem for all hole shots including the 1st. I fix my cars when I have the time and am reasonably mechanical, but don't know motors well. I'm pretty sure the dealer just wants to sell me a new motor so I am attempting to do this myself. Any ideas why I would lose power after the first hole shot? Thanks for any help!
BTW...Service manual is on the way...thinking about doing a carb rebuild.
