Northwest Ted
Thread starter- Joined
- Apr 30, 2016
- 4
I hope someone can help. I've replaced almost all my electrical components and I'm still only getting around 120 vDVA readings on my ignition coils which translates on the water to not being able to get over 4000 RPMs and the engine dying half the time when I shift into gear. I'm on first name basis with the CDI Techs and I can tell they are frustrated as well. History of the problem: 1990 Evinrude 150 XP on a Stratos bass boat. Engine rebuilt the spring of 2016 with all new seals, gaskets, check valves, rings, etc. After rebuild, engine would suddenly die about 40 minutes after running around. Temp related problem. Ruled out fuel issues and determined I was having a stator heat soak failure. Replaced the original stator with a CDI Stator. Engine ran fine for one outing then failed to get over 4,000 RPMs. Replaced ignition coils and power pack with CDI coils and power packs. Engine ran fine again initially then failed to reach 4000 rpm and then 2500 rpms. Sent all the parts back to CDI who then replaced the stator and three ignition coils. Installed replaced parts on engine and still topped off at 4000 rpm with ignition coil DVA readings at 120-125v. CDI replaced power pack (#2) and still no change. Ignition coil DVA measurements are at 120-125v. DVA out of stator and going into the power pack (brown wires) = 300v. Flywheel and magnets look great. I disconnected the voltage regulator and saw no change in DVA ignition coil numbers (Voltage regulator was replaced in 2015, no issues since with tachometer). Timing base (replaced 2013) tested and was told DVA numbers look good. This weekend I replaced a bad kill switch, and cleaned up all the engine grounds. No change. Disconnected the black/yellow kill wires to see if there was short in the kill wires. No change in ignition coil DVA numbers. Not sure where to go next? Any suggestions would be greatly appreciated!
