low compression ?
FRANK BURFITT
I have a 1977 johnson 55 hp i got the motor 2 week<br />ago and went to the lake only to find the motor running hot . replace water pump , thermostat and flush sys.{no more running hot thank guys for the help } I replace spark plugs and ck compression found the top cyl. at 150 psi and the lower cyl at 125 psi <br />with motor cold let run till it warm and recheck<br />compression it was the same is that ok or do i have a bad piston or rings ? or should i go back to the lake see how it runs ? dont want to hurt the cyl.wall so it cant be rebuild ? thank HD
WillyBWright
Re: low compression ?
Do they still offer Engine Tuner? It's a product that removes carbon from the combustion chamber like oven cleaner cleans ovens. Try that. Otherwise I don't think the 125 is bad enough to worry about.
