Low compression
searayray
Just got an 1988 Johnson 70 HP have not tested in the water yet runs on the hose OK compression is equal in all three but at 75lbs. I assume this is low. I could see if only one piston was producing a low number but all three what could cause this?
xtraham
Re: Low compression
confirm the compression gauge you are using, check @ operating temp., if it is still low decarbon engine w/seafoam and seafoam deep creep, those engines where lugged alot and will build carbon.
Dhadley
Re: Low compression
The gauge could be showing a bit low, the cranking speed may be slow, maybe it didn't turn over enough times, which head it has, etc. There are lots of variables. That's why OMC never gave a specific number but rather a range.
I'd have to agree with X -- do a good decarb and test again. I'll bet you're OK.
clanton
Re: Low compression
If your gauge is good, 75 is to low, also check the crankcase pressure.
