Low Compression on one cylinder
Toonfun
Hi folks,
I'm new to the forums and new to working on boats..(I do basically all the work on my cars so trying to apply as much of that knowledge as possible). I have a 1983 Johnson 115 V4 that is new to me. We originally had an issue with it not starting due to an ignition coil that the previous owner decided to solder rather than replace.. After replacing that I did a reroute of the fuel lines as it was a real cluster in there.
Now with muffs on the motor will essentially fire right up but if we put it in the water it bogs down and either idles very low or dies and if I put it in gear it will dies right away. I finally got my hands on a manual so I did a compression test to begin my diagnostic and all the cylinders are at 105ish but one which is at 30. I didn't have any oil to wet test that cylinder but I'm also not sure if that's even useful with it being that low.
I'm going to pour over the manual tonight but wanted to see if I could get any insight from the community here.
Thanks
ondarvr
These motors are known for breaking rings, so pull the head off that side and take a peak. It'll probably be in bad shape, so a total rebuild is kind of the only option.
jimmbo
There is a very small chance of a stuck ring. You could try soaking that cylinder with Engine Tuner, or another Combustion Chamber Cleaner. Just rotate the engine so the rings are above the ports and with the engine tilted up as high as it can go spray a generous amount of the cleaner in. Let sit several hours or a day or two. then expel it(makes a mess) the recheck compression. But you probably need to pull the head and look inside. Pulling the transfer cover will allow you to check the rings for tension and the piston for scuffing
Joe Reeves
All the cylinders are at 105ish but one which is at 30.?...... A 75 psi difference between the lowest and highest compression reading!
Remove the cylinder head before going any further. You either have a practically non existent piston or a blown head gasket. Perhaps you'll be one of the lucky ones.
Toonfun
I forgot to mention it sounded completely different when I was checking that cylinder. I actually went back to another cylinder to be sure my battery wasn't getting low as it sounded like it was cranking slower..but it cranked fine on the other cylinder.
interalian
I'd have expected it would crank FASTER on the cylinder with low compression, assuming you have all the plugs removed.
Toonfun
I had all plugs removed and had the engine warm but it sounded to me like it cranked slower or the battery was low which is why I tried another to check
Toonfun
Ok soo.. the piston has a nasty spot on it but the cylinder doesn't look scratched or damaged at all. Did I luck out or...?
jimmbo
The first picture shows damage when a piston ring breaks and snags the port
Remove the transfer port cover and check to see if the ring has any spring to it
ondarvr
It doesn't make much of a difference at this point, you need to totally disassembled the motor to fix it. And it will need a complete rebuild.
interalian
No Title
Yeah, you can see where the ring hit the port in this pic. A proper job needs the bores checked for wear, then pistons/rings at a minimum plus gasket set. Value proposition is up to you whether rebuild is worth doing.
