Low compression on all cylinders 60hp
gnewsome
Have a 1991 60hp johnson. Compression check revealed 90lbs on #1, 10lbs on #2 and 65lbs on #3. Could it be the head gasket? Any ideas would be helpful.
Solittle
Re: Low compression on all cylinders 60hp
Good place to start - What do the plugs look like?
Terry H
a great place to start...pull the head and look...just a Thought
D
DJ
Guest
gnewsome,<br /><br />The 10 psi scares me.<br /><br />Like the others said, pull the head and have a look.
clanton
After the new pistons and rings are installed, check all service bulletins, for upgraded cooling systems changes,and parts. Carbuator jet, and timing change, all posted on board.
