Re: Low compression on 9.9
Check your manual for compression specs. I have seen several people run them that low, as long as the cylinders are within 10% of each other, it is balanced enough to run.... Did you do a compression test with the engine warmed up? 75 lbs seems on the low side to me, but I have seen them run that low before.
