loud trim pump noise
Gary H NC
I was wondering what would cause the power trim pump to be noisy,trimming up it sounds fine but trimming down it is much louder,kind of like a screaming sound? i checked the fluid level and it was full.
sloopy
Re: loud trim pump noise
That is normal on some, as long as it is not a big difference in sound level.
Gary H NC
Thanks Sloopy,It seemed to get louder after i checked the fluid level? Maybe air trapped in system? It sounded like it sucked air in when i removed the plug to check it.
KRS
Banned
Be sure your grease fittings are well lubed... it might take care of it (if it isn't truly the trim fluid or pump).
Gary H NC
Thanks KRS..will investigate for more grease fittings..
