4.0l sahara
- Aug 15, 2007
- 298
Well I just got the 5hp johnson I bought on ebay. I think it's a 1966 could somebody tell me if i'm right.
model# LD-11r
serial# J2658492
My next thing I need to find out is why the gas line is leaking. I just bought a 3 gallon and a new hose for it it clips on but when I prime it it leaks at the connection to the motor. Is there a 0 ring that i'm missing?
Next is when I started the motor it ran nice but I whent to check the temp with a temp gun it had crossed the 200 mark. So I thought the water pump wat toast so I took off the LU and looked at the water pump and it looks okay so could the water jackets be cloged?
What is this key bellow the water pump called and what does it do?
Next is that there where three screws in the prop I have no clue what they do what do you think they do.
Next is the shaft just spins in the prop so how could I stop the shaft from turning so I can get the nut off?
model# LD-11r
serial# J2658492
