lost "spring" on drain plug from lower....
bluebrownie
end of last season when i was draining the lower unit lube... i took the screw out and there was a little spring on the screw...that fell on the ground.... i couldn't find it.... is that imperative to have that on or is that merely to allow for getting the screw in and out....?
R.Johnson
Re: lost "spring" on drain plug from lower....
That little spring was the thread's out of your gearcase.
