rfdfirecaptain
Thread starter- Joined
- Aug 17, 2008
- 314
I think this may be a Don S. question:
See signature below for engine and outdrive setup: While traversing north on the Intracoastal Waterway I had been on and off the throttle when meeting about 15 boats that were headed south. After about 40 miles I slowed to a stop and the engine was idling while I waited for a bridge to open. When I eased the throttle forward for idle speed to pass under the bridge I had no forward propulsion and I heard a whining sound. Also, I had no reverse.
I haven?t pulled the outdrive off yet, but I have made three key observations. #1 the engine is running perfect. #2 When the gear shift level is engaged the props are freewheeling. #3 I don?t recall hitting anything and there is no obvious damage to the props or outdrive. It sounds to me like I have sheared a key somewhere on the drive shaft.
I have rebuilt this outdrive and installed a new engine over the last three years, but I can?t remember all the mechanical details. Based on my recollection I think there is a keyway on the engine drive shaft, inside the transmission, that attaches the transmission spline shaft to the engine drive shaft, by way of a ?double female? coupler. Problem is, I just cannot recall how these parts are put together and to make a visual observation I would have to pull the engine. Of course I?ll know more once I pull the outdrive. In the meantime any help pointing me in the direction of where to look and what to look for is appreciated. Hopefully I?ll get the outdrive off later this afternoon, get the boat started up and see if the transmission driveshaft is spinning. Sadly, I still have to clean the boat etc. before I can get started working on it.
