Lost at this point
Cat man
I have a 70 ish year. 70 HP evinrude outboard. Runs well with a small miss on muffs. When in water will barely go 5 mph. Changed power pack 120 compression on all cylinders. Changed coils around. New plugs. Pulled head off cleaned top of pistons. Got spark and fuel to all cylinders. Tested today and worked fine for two passes across lake then sputterd n went back to lugging at 5 mph. Any ideas. And does this motor have points under stator
flyingscott
Sounds like it happens when it gets warm test the coils then. Have you gone through the fuel system could be tank/fuel pump or line. Does the primer ball go flat when it runs. Need a model#
Cat man
The fuel tank has no vent and when I open the lid after running it has allot of pressure is that normal or should I be cracking the lid for vent? I put a new hose with pump ball. I'm thinking maybe a sticky carb even tough they all been cleaned
pressure or vacuum? it needs to be vented. the slight miss at idle is an indication of either spark or fuel problem
AlTn
looks like a 1976 model...try cdielectronics/troubleshooting for ignition problems if each cylinder won't produce a spark that will jump a 7/16" open air gap...if you have a good spark, look to the fuel side for issues
Cat man
One coil seems like it has a weak spark so I will try that. Thank you all. I will keep you informed
emdsapmgr
Swap the weak coil with another coil. If the spark problem moves with the coil-replace the coil. If the problem does not move with the coil, then it's probably some other ignition component which is the problem. Power pack or timer base, or stator. That CDI website will tell you how to test each of those 3 ignition components.
oldboat1
carbs said to have been cleaned. would want to know what is meant by that.
