Lost 1500 rpm
99xjjoe
Blew the impeller and temps reached about 200. Changed impeller and cooling system is correct again. Now the motor will only rev up to 2700-3100 rpm, has power from idle to 3100, power is strong then just tops off there. Compression test showed 98 psi to 125 psi, which is within spec(75% of highest psi). Im focused on the fuel system now. Am i looking in the right area? No outdrive work done, no props changed just replaced impeller.
1996 5.0FL Volvo, SX outdrive Thanks Joe
