FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
From what I have read this unit would have a VRO (Variable Ratio Oil System) if this is the case your engine is adding oil itself. I could be wrong but I would check on this. If that is the case then you would not need to add any oil except to replenish the VRO.
they will be a little wet after idling,
what plugs are you using ?
does the engine have vro and is it working ?
you will need to check the compression and
check each coil for bright blue spark with a spark testor
