Re: Loss fo Performance and Efficiency
There is a cavatation issue with the new Yamaha gear case. They have moved the water pick up location on the lower unit. Yamaha has move the pick up lower on the case. Yamaha recommends to file the leading edge of the case. I've tried it doesnt help. I have put T-H transom shim in to help. I think they should have put a low water pick up in like Mercury big case. The lower unit where running out of water on the top end. I bet a another new case will come out with a low water pick up. The new engines have rpm reduction when you run them hot. Thats why they had to address this issue. We have been putting nose cones on these engines for years with low water pick ups.
