Losing Propeller Thrust
interalian
Did you try marking across the prop and cap to see if it slips?
Drive pin fits in the bronze hub, and there's a rubber slug molded around the hub and the inside of the prop cavity. Or a press-fit into one or the other.
BigD9105
Exactly right jakedaawg. We used to carry short pieces of brass rod to replace ours when we hit a log or rock. Just don't drop the carter key or nut in the water. Easy fix.
wilberking
I did make a mark on the hub and prop and turned the prop while in gear. The prop slipped the instant I got some torque in it. And the marks were not lined up afterwards. Photos here : https://goo.gl/photos/k2926UzdaaxhRaM76
So do I replace the prop? Is that the simplest thing to do?
Thanks.
phillnjack2
Ensign
might as well buy a nice new prop for it. keep that old one as a ornament in the garage.
or you could drill it and make it solid and keep as just an emergency spare ..
wilberking
Ok. So the existing prop looks like it's got 8 1/4 X 8 1/2 stamped on it. So I should get the same sized replacement ..... right?
Yes these props have rubber hubs in them.---Even the 6 hp had a rubber hub !--------Had someone drive a distance to pick up a used prop after they priced a new one !
