losing power
scrapy
I have a 79 johnson 235 the engine bogs down as if i hit some thing when a let off the throttle wait about 10 seconds or put it in reverse and power back up to 4500 its fine for only about a 1 to 2 min. and then the same thing.and sometimes its fine and wont happen for 10 min.
angus63
Re: losing power
Check primer bulb when this occurs. If soft or collapsed, you have a fuel restriction before the bulb. If firm, try the pump intake screen for crap. Lastly, diconnect fuel pump output when running and check for flow. Sounds like not enough fuel getting to bowls and they are running dry. Might be fuel pump diaphram leak. Oh yeah, make sure all of your fuel lines are tight and not suckin air.<br />good luck
