losing bottom
captn-tin
just installed a lowrance x-88 on my 16' westcoaster. low speed depth seems to be right on, but when i get up to about 20 - 22 mph the unit seems to lose bottom. in water i know to be about 40', it will read anywhere between 100 and 1200 ft!. when i slow down to about 10mph, the wrong depth reading will start flashing, and then go down to the correct depth. i am using a 200 khz-20degree single transducer, not the dual frequency transducer. anyone out there know how to correct this problem? thanks in advance....captn-tin
Gary H NC
Re: losing bottom
Sounds like at higher speeds the transducer is getting air under it.That is if its transom mounted. If its mounted inline with a strake in the hull that could do it too. Try adjusting it lower..
Silvertip
Honorary Supreme Mariner
Re: losing bottom
Or its flipping up at speed and dropping back down at slower speed.
