loosing spark
ssonline888
hi there i have a 75 model chrysler 75hp that looses its spark after running for a while when it cools down it seems to start i have replaced the magna pack and coil but no luck anyone have any ideas p/s when i move the controls back and forth it sometimes starts could it be the neutral switch would like any help thank you shane.
Nordin
Re: loosing spark
I don not think it is the neutralswitch, it just cut out power to the startersolenoid. What kind of distributer do you have? With points or with preamplifier eay? If preamplifier, it can be the issue. Electroniccomponents are sensetive from heat and even more if it is old. If you have points change the condenser it is also sensetive from heat when it gets old.
Frank Acampora
Re: loosing spark
Also check under the back of the flywheel. The wires pass there and sometimes they rub on the underside, wear the insulation, and short when vibration makes them touch the wheel. Engine stops, cools, circuit breaker resets, and it will start and run again.--for a while until it happens again.
This is not likely since you already tried changing the power pack, but is worth checking anyway.
Due to slop in the cables, sometimes the neutral switch is not centered and the starter will not engage. The easiest cure for that is to move the controls as you are doing. However, once running a stalling problem has nothing to do with the neutral interlock. You need to check the wiring, distributor, and the ignition switch for that problem.
ssonline888
Re: loosing spark
Hi there it has a preamplifier no points p/s where would i get one from thank you shane.
Nordin
Re: loosing spark
CDI is the aftermarket manufacter art.nr. 135-4048. I know maxrules.com has it for 130 bucks, Franz Marine (FranzMarine.com) may have factory made but also CDI made. There are more out there that has it. Goolge on CDI 135-4048 and you may got many hits.
