92 evinrude 28 hp fowling plungs
meff60
How do I determine what is causing the fowl plugs. It idles great but as soon as I cut it loose the motor dies. The top plug is fowling, but the bottom does not look bad. Its missing a little when I up the rpms in neutral, but does not die unless in gear. I also have some gas/oil coming out the front of the carb.
wilde1j
Re: 92 evinrude 28 hp fowling plungs
What model plugs and the gap? Gas coming out is probably the needle valve not seating in the carb. You may have to clean/rebuild carb.
Fouled plugs are usually caused by motor running too cold or too rich. Have you tested the thermostat operation?
meff60
I am using autolite xs 4093 plugs, gap not sure. I just ordered the 91-94 evinrude/johnson 2-300 hp manual. Im thinking it has to be the needle seat in the carb. I checked volt on both coils and got the same result. I also checked compression and got 120 out of both cylinders.
wilde1j
Get the correct Champion plugs which your motor was designed to work with. I don't think you'll be too happy with the manual if it's not an OEM book. The 3rd party manuals are short on important details.
meff60
thanks, that was going to be my next move just wanted to make sure
meff60
I ordered the manual from clymer.com. so you think I should cancel it?
wilde1j
Yep, get a manual from this site or Ebay.
meff60
thanks again, hopefully the cleaned carb will do the job. I got way too much money into my boat and not enough fishing going on! It ran pretty good the first 4 times out this summer.
meff60
should this motor on a 14' sabre craft haul 3 adults totaling 650 lbs, and i ask because it wasn't until I did that that I noticed any problems.
tashasdaddy
not knowing the boat, i understand it is a old boat. can't say. it will do it but not fast. post picture of the boat.
meff60
wilde1j
Motor should plane that boat. I had a 28HP on a 14' fibreglass Starcraft similar to a Whaler and it planed the boat just fine, but not too fast, say ~ 25 MPH.
tashasdaddy
i would expect 25 with 2 people, you have the same problem i have with one of my boats, you either put a person up front, or you both are basically in the stern making it harder to plane.
meff60
any clue on the float height in the carb bowl, carb looks pretty clean and needle doesnt look bad
wilde1j
Carb should not be "pretty clean", it should be spotless after soaking in carb solvent and blowing dry with compressed air. Most have the float even with the bowl parting line, but I don't have a manual for your motor.
