jrmcgee1972
- May 22, 2007
- 3
1st issue, im not mechanically inclined whatsoever.
The engine starts and runs great. However, in order to start the engine I have to remove the cover and physically push the starter against the flywheel. If not the teeth dont engage enough to turn flywheel. when i push the starter against the flywheel- no problem- starts right up.
I noticed two empty screw holes, one on top of the starter casing and the second on the right side (As you're looking toward the bow) of the engine. They are the same size and it almost looks like there is a missing "bridge" that would serve to hold the starter tight to the flywheel. Looks like all i need is that bridge and two bolts. If anyone is able interpret my garbled description of this issue and can tell me the name of the part Id be grateful.
The parts department at my local shop suggested I need a new "Starter bracket". I dont think that is what I need based on my online research.
Thanks- JRM
Thanks- JRM
