Looks like my idle problem is fixed. Kind of
stoked not
After reading several post about idle problems It looks like I got mine fixed. Want to give back to the board. Last fall I purchased a 22' Stratos w/a with a 1991 225 Johnson I thing that the boat sat alot, it was owned by an older couple. Well, after chasing down some electrical problems (power pack and stator) I still had a idle problem when I put her in gear (under a load) She would sneeze and stall under 11000 rpms. I purchsed a can of Engine Tuner and now she running good. She idles in gear at 600 RPM's The only time she sneezes is at 900 RPM's, every other speed is great. Any ideals? Should I run more engine tune since my first results were good?<br /><br />Thanks<br />Stoked ;)
stoked not
Re: Looks like my idle problem is fixed. Kind of
Bump ^
