Looks Like A Oil Filter
mcgill
I Have A Bass Boat 87 Winner This I Found I My Fule Compartment THE ONE ON THE LIFT It Looks Like A Oil Filter On A Car Is It?
Also THE PHOTO ON THE RIGHT I See Two Black Caps On Back Of My Bass Boat WHAT ARE THAY AND HOW DO YOU REPLACE THEM ?
mthieme
Re: Looks Like A Oil Filter
That's a standard marine fuel filter.
The caps appear to be guards for the outlets of the self bailing hull.
CharlieB
The filter is water separating, to keep any water in the tank from fouling your carbs, leaning out a cylinder and melting a piston.
The black caps are water INLETS to the live well pumps.
mcgill
Thank You For That Information
:)Also Do You Know How To Replace The Two Pumps ? I Am Think Of Doing It My Self Or Do I Need To Hiyer Some One?
Silvertip
Honorary Supreme Mariner
If you know which end of a screwdriver to hold you can do the pump replacement yourself. Undo the clamps, unfasten the pump, disconnect the wires and remove it. Pumps are generic so there is no real need for an exact replacement. Just make sure the pumps are bad before you replace them. It may just be a bad switch, broken wire, or disconnected wire somewhere in the system.
